i3 MK3s
I updated Octoprint 1.9.0 and printer's firmware to 3.12.2. Now printer will stop, it appears to be randomly, and ask for a filament swap. Anyone experiencing this issue? If so, does anyone come up with a fix?
Thank you
RE: i3 MK3s - (filament change)
I have the same problem. I tried printing from an sd instead of octoprint - no improvement. I tried the rc2 Průšaslicer - no improvement; tried slicing with cura 5.3 and it went longer before requesting filament change but then just like the other attempts, constant demands to change filament. There is no feed problem
RE: i3 MK3s
@petert thanks for your reply. I glad I'm not the only one reporting an issue. I also tried printing off SD card with same result. I'll have to revert back to pervious firmware version. Hope Prusa addresses this issue.
