i3 mk3s+, Octoprint, Pi Zero 2 W, camera?
Scryptic
(@scryptic)
Has anyone who has started using Octoprint on the Pi Zero 2 installed a camera?
If so, which model are you using (Of camera)
Did you encounter any issues to get the Camera to work?
Thank-You for your time.
-= Bruce
Veröffentlicht : 15/02/2023 3:51 pm
Extra Fox
(@extra-fox)
RE: i3 mk3s+, Octoprint, Pi Zero 2 W, camera?
I'm not sure that you'll be able to run both off the Pi Zero 2. In fact, the Author of Octoprint has gone to some lengths to warn people that the Pi Zero isn't suitable for the software.
When I ran it, it could handle the bare minimum. That being uploading and handling the printing and honestly, it did that fine. When it came to wanting to run plugins and a camera though, it was not up to the task. So I went with a Pi 4.
Aaron
Veröffentlicht : 15/02/2023 5:11 pm
JimB
 JimB
(@jimb)
Don't confuse the Pi Zero with the Pi Zero 2.  They are very different.
At https://octoprint.org/download/ it says "Recommended hardware: Raspberry Pi 3B, 3B+, 4B or Zero 2"
Veröffentlicht : 15/02/2023 8:38 pm
Extra Fox
(@extra-fox)
True enough, sorry about that. I looked right past the "2".
Aaron
Veröffentlicht : 15/02/2023 8:48 pm
JimB
 JimB
(@jimb)
I am using the "official" raspberry pi camera with a 3B+ and many plugins installed.  No problems.  I even routinely display the camera feed on two other systems at once (desktop and tablet).  Main differences performance-wise from 3B+ to Zero2 are: CPU clock (1.4G -> 1G), RAM (1G -> 0.5G)
Veröffentlicht : 15/02/2023 9:01 pm
Extra Fox
(@extra-fox)
I took it to the extreme and went with a Pi4 with 8GB of RAM. It's almost assuredly overkill, but it's definitely not struggling.
Aaron
Veröffentlicht : 15/02/2023 10:07 pm
Bob
 Bob
(@bob-17)
Any issues using the Pi4? I assume you power it separately and connect the grounds?
Any issues with a ribbon cable connecting the Pi to the Einsy?
Veröffentlicht : 17/02/2023 10:11 am
Netpackrat
(@netpackrat)
I am not the guy you were asking, but I am running a Pi4B with 4gb on each of my printers for Octoprint.  Which I guess is only half as much overkill as Extra Fox is running?  Separate power supplies off the same power strip/surge protector that the printer is plugged into.  USB connection and it works well.  Not sure what would be the point of using a ribbon cable to connect Pi to Einsy since USB is easy and works well.  The only ribbon cable I am running is to the Pi camera for remote monitoring.
https://www.printables.com/@Netpackrat/models
Veröffentlicht : 17/02/2023 10:53 am
Bob
 Bob
(@bob-17)
Thanks for the reply.
So theres no need for the Pi Zero then?
Is that offered purely as a nice compact solution?
Thanks again,
Veröffentlicht : 17/02/2023 11:14 am
Extra Fox
(@extra-fox)
My setup is almost entirely like Netpackrat's.
I have an independent power supply for the Pi4. Previously I was just using one of the Pi4 rated plug in transformers, but since moving the whole contraption into an enclosure I now use a step-down converter from a 12v supply. In that process I did learn that the quality of the USB cable delivering the power seems to be paramount to making sure it doesn't under-volt.
I can't comment on the ribbon cable as I use one ribbon to connect a display and the other to a camera. I have a USB-A to USB-B cable connecting the Pi4 to the Einsy.
Aaron
Veröffentlicht : 17/02/2023 3:13 pm
Pi zero was an attempt at a simple, compact solution.
the pi zero works but has limited capabilities
Joan
Veröffentlicht : 18/02/2023 9:11 am
In the early days of Octoprint the Pi Zero was more than capable of handling the task and still is if the basic function is all you need - but Octoprint grew and left the Pi Zero behind ... Luckily the Pi also grew and the Pi Zero 2 more than caught up - which of them contines to grow faster is anyone's guess.
Veröffentlicht : 18/02/2023 1:52 pm
Scryptic
(@scryptic)
Pi Zero 2 is fine. I have hundreds of hours of prints using it for both OctoPrint and capturing timelapses.
Veröffentlicht : 29/07/2023 7:45 pm
DaddyBoomalati
(@daddyboomalati)
Hello,
My RPi 4 has died and I was thinking of the Zero 2 W. I just want to check that you have tried it with the Pi camera and it works okay?
Thanks!
Thanks,
Dave Smith
Veröffentlicht : 03/11/2023 2:48 pm
Hello
(@hello)
Posted by: @daddyboomalati
Hello,
Thanks!
Yes, as long as you get the adapter cable
Veröffentlicht : 03/11/2023 5:49 pm
DaddyBoomalati
(@daddyboomalati)
Is it different than the normal ribbon cable?
Thanks,
Dave Smith
Veröffentlicht : 03/11/2023 6:29 pm
Walter Layher
(@walter-layher)
There are two different kinds of Raspberry Pi CSI camera connectors: 15-pin and 22-pin. The 15-pin connector is mostly seen on standard Raspberry Pi models (A&B series) and Pi camera modules; the 22-pin is on Raspberry Pi Zero-W and Compute Module IO Board.
You probably need this adapter cable here.
Veröffentlicht : 03/11/2023 7:10 pm
Hello
(@hello)
Posted by: @walter-layher
Yes that's the right cable
Veröffentlicht : 03/11/2023 7:11 pm
Hello
(@hello)
Veröffentlicht : 03/11/2023 7:12 pm
