I could use some help with measurements of some holes on the frame.
ShaneTalksTech
(@shanetalkstech)
Hello everyone,
I am in the process of working on adding a Raspberry Pi to my MK4 for Octoprint. I have a question about some mounting points on the frame of the MK3S compared to the MK4.
I am looking at using this print for my project:
https://www.printables.com/model/58012-raspberry-pi4-case-for-prusa-mk3s-with-dsi-opening
As you can see there are two diagonal holes where this attaches to the left side of the frame on the MK3S.
There are holes on the MK4 as well.
I was wondering if anyone who has an MK3S could measure the distance between this mounting points for me so I can compare that to the frame of my MK4.
I am trying to see if these two frames are the same in this regard or if I need to change the model a bit to fit my printer.
Thanks in advance!
Postato : 14/02/2024 2:07 pm
