Heater Block Silicon Sock?
Pagina 1 / 2
iftibashir
(@iftibashir)
Is it advisable to place a silicon sock on the heater block?? Is this only to stop plastic sticking to the heater block and keeping it clean, or will it have any affect on print quality? ie, will it affect the blower/cooling fan when printing etc?
Postato : 18/01/2023 10:43 am
jsw
 jsw
(@jsw)
RE: Heater Block Silicon Sock?
I've always used that non-stick coating in lieu of a sock.
Postato : 18/01/2023 10:46 am
iftibashir
(@iftibashir)
I'm reading a sock helps 'regulate heater block temperature' etc for higher quality prints - wondering if its just a marketing gimmick or whether they actually make a difference?
I guess they are cheap enough to just use for added protection if anything else......
Postato : 18/01/2023 11:15 am
jsw
 jsw
(@jsw)
I would question the significance of that assertion.
Posted by: @iftibashir
Postato : 18/01/2023 11:25 am
Netpackrat
(@netpackrat)
Been printing for less than a year, and have had a couple of (genuine E3D) socks deteriorate and mess up prints.  I am still using them, but I try to keep a close eye on condition.  I think on the whole they are probably a benefit.
https://www.printables.com/@Netpackrat/models
Postato : 18/01/2023 11:26 am
I always have a proper E3d silicone sock fitted.  Wouldn't print without one now.
As well as making clean-up easier it does help regulate temperature of the hotend, inasmuch as you will quite often get the part fan cooling blowing up from the bed for the first few layers, or some part geometries can redirect the air back upwards and cause dips in the extruder temps.  A sock blocks nearly all of that.  That's probably more useful than the help with clean-up.
Don't forget to run a temperature PID after fitting one though.
Postato : 18/01/2023 11:32 am
1 persone hanno apprezzato
iftibashir
(@iftibashir)
LCD Menu -> Calibration -> PID calibration?
Posted by: @neophyl
Postato : 18/01/2023 11:41 am
Yes.  That process should be done anytime you change anything like the thermistor or heater cartridge too.
Although with Prusa's 3.12 firmware they have that new thermal model stuff so I'm sure that replaces the PID requirements.  Then again with all the issues 3.12 seems to be having with it I wouldnt update to it at this point.  Needs a bit more maturity/testing I think.
Postato : 18/01/2023 11:50 am
iftibashir
(@iftibashir)
Are there any cooling issues when using a silicon sock?? ie, does it hinder part cooling as you print due to the extra thickness of the sock maybe blocking some of the cooling from the fan shroud?
Postato : 18/01/2023 12:02 pm
I don't recall it being a problem when I had the original Mk3s fan shroud fitted.  I didn't run with the Mk3 shroud for long though so cant say if there would have been long term problems and I notice there are several 'sock friendly' shroud alternatives on printables.
That was awhile ago though.  I was running a different fan shroud (RHD version https://www.printables.com/model/116791-prusa-mk3s-rhd-cs-fan-shroud-mk3s-mk25s   ) for a long time and I very recently swapped to a new one that allows you to view the nozzle while printing (a variant of the Delta-P fan shroud) .  Still evaluating that one though.
Postato : 18/01/2023 12:25 pm
In my view the question of whether to use a silicone sock or not will solicit the same sort of response as asking whether God exists. Some are true believers. Others (including myself) suspect they're a gimmick with little practical value.
But the same way that I am an agnostic, not an atheist, I have no problems with people believing in silicone socks. I just have no evidence from my own practice that confirms that perceived value. And like pretty much anything else in 3D printing, personal experience—not any kind of significantly scaled and reproducible scientific data collection effort—is really what's driving people's view on this topic. In my case, I've used socks for months in the past, saw no benefits but had a few more blob issues than before, so stopped using them and never looked back.
TL;DR: Whether socks are good or bad, who knows. I don't see value in them, but I may well be wrong.
TL;DR: Whether a sock make sense, I don't know.
Postato : 18/01/2023 1:38 pm
2 persone hanno apprezzato
iftibashir
(@iftibashir)
Thank you guys for your input - appreciated as always.
I've had no issues with my prints so far so I think I'm going to stop looking to solve issues I do not have and will continue to run stock for now. I'm trying to bulletproof my printer and just need to stop and take a step back to appreciate that it seems to be doing the job fine as it is! lol
Thank you for the valuable information and opinions.
Postato : 18/01/2023 3:43 pm
Wiser words have not been spoken.
Unless you're truly into tinkering, most "upgrades" and "improvements" are not worth it, usually with marginal positives for some edge cases and often in fact detrimental.
How many times do we see posts here from folks that need help (and often bitch about their printer) just to discover that they have "improved" their hardware or software to the nth degree.
Postato : 18/01/2023 4:51 pm
Extra Fox
(@extra-fox)
I ran for several years without and, but bought one recently to try it out. Being the curious sort that I am.
It's actually been really nice to use and does keep the head much cleaner. I've also had no issues with cooling or anything of the sort, but your mileage may vary depending on your unique setup. I'm running a Mosquito hot end with their high temperature thermistor.
The one thing I have noticed is that the nozzle heat seems to change the properties of the silicon. It becomes hard and brittle over time.
I think I'll try the non-stick coating next.
Aaron
Postato : 18/01/2023 9:05 pm
iftibashir
(@iftibashir)
Posted by: @extra-fox
Something like this?
https://www.amazon.com/Slice-Engineering-Plastic-Repellent-Paint/dp/B08DZ69MYD/ref=sr_1_1?crid=26280VXDBAJ6M&keywords=slice+plastic+repellent+paint&qid=1674123334&sprefix=slice+plastic+repellant+pain%2Caps%2C141&sr=8-1
Postato : 19/01/2023 10:16 am
Extra Fox
(@extra-fox)
Yup, that's the stuff.
Aaron
Postato : 19/01/2023 3:04 pm
Extra Fox
(@extra-fox)
It might actually be cheaper for you to buy the paint-on stuff directly from Slice Engineering; even with shipping. It will also benefit Slice more as they won't be dinged by Amazon taking their cut from the transaction.
https://www.sliceengineering.com/products/plastic-repellent-paint
Aaron
Postato : 19/01/2023 3:13 pm
jsw
 jsw
(@jsw)
The Slice Engineering is what I was referring to above, assuming I remember to put it on when I clean off the heat block.
Postato : 19/01/2023 3:14 pm
Artur5
(@artur5)
Some days ago I replaced the nickel platted copper nozzle of my MK3S+ with a new TC unit from 3Dmaker engineering. That poor nozzle had been on duty for 15 months and it deserved a retirement, specially after printing a bit of CF nylon filament.
When I removed the silicone sock to swap nozzles, I saw that the whole hotblock of the Mosquito hotend was still shiny and clean as new and the thermistor/heater wires were free from any residue. The same silicone sock was in quite good condition, very flexible and basically undamaged, just a bit stained with a greyish coat where it touched the nozzle or hot block. It wasn’t a genuine Slice Eng, sock, but a cheapie from AliExpress.
In my point of view, there’re no drawbacks using a sock, only benefits.  I’m not trying to ’convert’ anybody who thinks otherwise, just saying that no hotblock of mine will print anymore without a sock.
Postato : 19/01/2023 6:51 pm
4 persone hanno apprezzato
SG Newb Rider
(@sg-newb-rider)
It's all fun and games, until sticky filament gets all over the hotend, gunks up the grub screws and you can't remove your heater and thermistor cartridges. A sock is absolutely worth it, even if it does nothing for actual printing
Postato : 31/01/2023 1:07 am
Pagina 1 / 2
