Firmware upgrade via USB with octoprint on R PI 3B ???
ad.lamy
(@ad-lamy)
Has anybody achieved an upgrade with the firmware upgrader in octoprint on MK3
Installed latest octopi 0.15 with octoprint 1.3.8 on my Raspberry PI 3B
WIFI OK
Server start
Connect to the printer and print with no problems
Installed firmware upgrade plugin
Installed avrdude
avrdude path correct
set AVR MCU to Atmega2560
set AVP prog to wiring
RPI port disable on the printer
Disconnect from the printer in octoprint menu before upgrade
port set to /dev/ttyACM0
browse path to the .hex file
Hit flash button
Progress bar appears but nothing appens
No message on the printer
On the other hand I can upgrade from the command line through ssh connection with .hex file uploaded on the PI.
An idea ???
MK4/MMU3 - VORON 2.4 350 Stealthburner
Opublikowany : 22/05/2018 3:36 pm
GertL
(@gertl)
Re: Firmware upgrade via USB with octoprint on RP PI 3B ???
I did this on my MK2.5 yesterday for the first time from OcotPrint.
There was no messages at all but after a long nervous wait the printer was updated.
Gert
Opublikowany : 22/05/2018 3:39 pm
neil.e
(@neil-e)
Re: Firmware upgrade via USB with octoprint on R PI 3B ???
Worked fine for me flashing the last two updates via Octoprint on a Pi B connected over USB.
Opublikowany : 23/05/2018 1:11 am
ad.lamy
(@ad-lamy)
Just fix It,
Set also baudrate to 115200 in the plugin advanced settings.
Works fine...
Opublikowany : 23/05/2018 11:46 pm
