Firmware Notification & Octoprint
kimonache101
(@kimonache101)
Hello everyone,,
I am using Octoprint on my MK3 and that all fine. Recently whenever I go to print from Octoprint, the MK3 beeps and says there is an update available or something to that effect on the LCD screen. Octoprint will not print until I walk over to the printer and press the knob in.
Not an issue when I am home but when I want to start a print remotely, i am SOL until i get home.
Of course, I understand its only an issue because I haven't updated but its something that could occur every time firmware gets updated.
Is there a timer, a way to turn off the notification, or a way to continue my print remotely?
Thank you,.
https://speedtest.vet/https://vidmate.bid/
Napsal : 05/03/2020 10:51 am
richard.l
(@richard-l)
Member Moderator
RE: Firmware Notification & Octoprint
Under printer settings in PrusaSlicer, in the Custom G-code section either remove the M115 line or place a semi-colon in front of it.
Napsal : 05/03/2020 1:50 pm
Peter M
(@peter-m)
Use the same version of the prusa slicer and the firmware.
Download en update these 2 together, then you do not have this problem.
if you update only prusa slicer, and use a older firmware, the prusa printer sees this.
Napsal : 08/03/2020 6:56 pm
Lichtjaeger
(@lichtjaeger)
You can turn off firmware checks in the hardware settings.
Napsal : 08/03/2020 7:05 pm
