extruder problem
armin.s4
(@armin-s4)
extruder problem
Hello,
I have a new MK3 printer, used since one month with PLA filaments.
I have started using once moth before, and everything worked perfect, I have printed many parts with different type of PLA filaments.
Suddenly I have problems with extruder :
When I print small parts, no issue, everthing works fine. If I print big parts, like lets say a cylinder of 80mm diameter, long linear lines to print always after some minutes, the filaments refuses to go into the nozzle, and intermittent there is no PLA at the output of the extruder, and you can hear the noise, when the stepper motor can not introduce the filament into the extruder.
Any ideas ?
thanks in advance for your help
Armin
Postato : 19/01/2019 3:13 pm
thrawn86
(@thrawn86)
Re: extruder problem
you've got a jam
Postato : 19/01/2019 5:25 pm
armin.s4
(@armin-s4)
Thanks
I removed noozle, cleaned it out, and everthing reworks perfectly.
thanks very much
Armin
Postato : 20/01/2019 7:56 am
