Do I need a printer config upgrade in PrusaSlicer after a Revo upgrade?
I'm solid on the upgrade process and firmware flash but do I need to do anything to the slicer config? Given its the same or nearly the same in z-height, 40w and doesn't change anything with the printed files of the hot end, the Prusa supplied configs should still work fine, right?
Napsal : 27/12/2023 9:06 pm
RE: Do I need a printer config upgrade in PrusaSlicer after a Revo upgrade?
I did not change anything in PrusaSlicer after installing the Revo 6 on my MK3S+. Everything works the same as before.
Napsal : 27/12/2023 11:27 pm
I very recently changed over to Revo6 and only took the printer firmware back as recommended, I never touched Prusaslicer. So far, seems to be working a treat.
Napsal : 28/12/2023 7:06 am
