Change firmware when printhead dimensions change? X-Homing position
I want to replace the small noctua fan with a different one. The power supply / PWM is a topic but solvable.
My Question is:
The new fan is slightly higher than the original noctua. How will this affect the homing and calibration procedure? I had a look at the firmware configuration.h etc. but it would take a while to get to know it - especially when the probe is involved.
Opublikowany : 01/03/2019 3:46 pm
Re: Change firmware when printhead dimensions change? X-Homing position
A taller fan (thicker than about 12mm ) will cause a failure on X-Axis length.
Opublikowany : 02/03/2019 5:03 am
