Canot cancel print in Octoprint
cezary.j
(@cezary-j)
Almost every time if I cancel print Octoprint it's get stuck in Canceling and I have to disconnect and reconnect fix this it's FU***** annoying
Problem exists since update to 1.3.8 version of Octoprint
I dont know on which side this bug is so I print here because I used Prusa Print ROM for Raspberry Pi zero which should work with Prusa printer
dump from console
Send: N11182 G1 X229.918 Y30.274 E0.01666*85
Recv: ok
Send: N11183 G1 X229.332 Y30.266 E0.01671*83
Recv: ok
Send: N11184 G1 X228.747 Y30.222 E0.01671*83
Recv: ok
Send: N11185 G1 X228.166 Y30.143 E0.01671*83
Recv: ok
Send: N11186 G1 X227.591 Y30.030 E0.01671*86
Recv: ok
Send: N11187 G1 X227.023 Y29.882 E0.01671*82
Recv: ok
Send: N11188 G1 X226.466 Y29.701 E0.01671*93
Recv: ok
Send: N11189 G1 X225.920 Y29.487 E0.01671*93
Recv: ok
Send: N11190 G1 X225.388 Y29.240 E0.01671*80
Recv: ok
Send: N11191 G1 X224.873 Y28.963 E0.01666*82
Recv: ok
Send: N11192 G1 X224.133 Y28.485 E0.02512*90
Recv: ok
Send: N11193 G1 X223.433 Y27.950 E0.02512*83
Recv: ok
Send: N11194 G1 X222.999 Y27.559 E0.01666*94
Recv: ok
Send: N11195 G1 X222.587 Y27.141 E0.01671*87
Recv: ok
Send: N11196 G1 X222.202 Y26.700 E0.01671*92
Recv: ok
Send: N11197 G1 X221.843 Y26.236 E0.01671*81
Recv: ok
Send: N11198 G1 X221.513 Y25.751 E0.01671*81
Recv: ok
Send: N11199 G1 X221.212 Y25.248 E0.01671*91
Recv: ok
Send: N11200 G1 X220.942 Y24.727 E0.01671*90
Recv: ok
Send: N11201 G1 X220.703 Y24.192 E0.01671*88
Recv: ok
Send: N11202 G1 X220.497 Y23.643 E0.01671*89
Recv: ok
Send: N11203 G1 X220.325 Y23.083 E0.01671*92
Recv: ok
Send: N11204 G1 X220.186 Y22.513 E0.01671*93
Recv: ok
Send: N11205 G1 X220.081 Y21.938 E0.01666*90
Recv: ok
Send: N11206 G1 X219.993 Y21.061 E0.02512*95
Recv: ok
Send: N11207 G1 X219.976 Y20.180 E0.02512*90
Recv: ok
Send: N11208 G1 X220.011 Y19.597 E0.01666*92
Recv: ok
Send: N11209 G1 X220.081 Y19.015 E0.01671*93
Recv: ok
Send: N11210 G1 X220.186 Y18.438 E0.01671*89
Recv: ok
Send: N11211 G1 X220.325 Y17.868 E0.01671*85
Recv: ok
Send: N11212 G1 X220.497 Y17.310 E0.01666*90
Changing monitoring state from "Printing" to "Cancelling"
Recv: ok
and Octoprint log for this event
2018-05-23 09:09:19,281 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2018-05-23 09:09:19,283 - octoprint.server - INFO - OctoPrint 1.3.8
2018-05-23 09:09:19,306 - octoprint.plugin.core - INFO - 12 plugin(s) registered with the system:
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements
| Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard
| !CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
| GcodeEditor (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GcodeEditor
| ipOnConnect Plugin (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ipOnConnect
| Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging
| OctoPi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/octopi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| Printer Safety Check (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
| Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2018-05-23 09:09:19,476 - octoprint.environment - INFO - Detected environment is Python 2.7.9 under Linux (linux2). Details:
| hardware:
| cores: 1
| freq: 1000.0
| ram: 388681728
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: Zero W
| revision: 9000c1
| version: 0.14.0
| python:
| pip: 9.0.3
| version: 2.7.9
| virtualenv: /home/pi/oprint
2018-05-23 09:09:19,479 - octoprint.server - INFO - ------------------------------------------------------------------------------
2018-05-23 09:09:19,266 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-05-23 09:24:19,487 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-05-23 09:24:35,737 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2018-05-23 09:24:35,819 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-05-23 09:39:19,490 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-05-23 09:45:51,917 - tornado.access - WARNING - 409 POST /api/files/local (127.0.0.1) 140.88ms
2018-05-23 09:47:22,719 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2018-05-23 09:47:22,723 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Red_box.gcode
2018-05-23 09:47:22,752 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/Red_box.gcode
2018-05-23 09:54:19,496 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-05-23 09:54:47,235 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Offline"
2018-05-23 09:54:50,554 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-05-23 09:54:50,601 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2018-05-23 09:54:50,687 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-05-23 09:54:50,738 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2018-05-23 09:54:50,826 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-05-23 09:54:50,909 - octoprint.util.comm - INFO - Printer reports firmware name "Prusa-Firmware 3.2.1 based on Marlin"
2018-05-23 09:55:09,310 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.1.7
Postato : 23/05/2018 11:54 am
Knickohr
(@knickohr)
Utenti Moderator
Re: Canot cancel print in Octoprint
Please post this in the octoprint forum.
PRUSA doesn't support 3rd party software.
Thomas
Postato : 23/05/2018 12:34 pm
Erik
 Erik
(@erik-3)
I also have this problem. I just disconnect and reconnect OctoPrint and then raise the Z manually once it reconnects (and resets the printer). It's janky, but it works when I REALLY need to cancel a print.
Postato : 23/05/2018 2:37 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
I don't know what the issue is here. I run OctoPrint 1.3.8 running on OctoPi 0.15.0 with both Mk2S+MMU (3.1.0) and Mk3 (3.2.0.555) and can cancel via Octoprint whenever needed and without issue.
It may be PR firmware (I believe there are still issues with it not generating sufficient "ok" responses) or it may be Octoprint or its settings.
You may want to check that Octoprint Tools/Serial Connection/Firmware & Protocols/Firmware Specific/Advanced has "Simulate OK for M29" checked and "Simulate OK for Resends" set to "Always".
Peter
Postato : 23/05/2018 3:13 pm
cezary.j
(@cezary-j)
Thomas
I wrote and my post was removed, by the way they said that Pi Zero is not supported so ......
Postato : 23/05/2018 7:35 pm
cezary.j
(@cezary-j)
Peter
I checked everything this also and still can't cancel print, problem is present since update to 1.3.8 so there is no error on my end
Postato : 23/05/2018 7:37 pm
cezary.j
(@cezary-j)
I got it, here is workaround
https://discourse.octoprint.org/t/octoprint-1-3-7-1-3-8-is-stuck-in-pausing-or-cancelling/1625
Postato : 23/05/2018 8:58 pm
PJR
 PJR
(@pjr)
Yes, and I would not consider using a Pi Zero to do this job. You really do need a multiple-core Pi MCU.
Peter
Postato : 24/05/2018 11:31 am
