Can I change Enclosure Humidity/Temp Display to Deg F?
4x4dually
(@4x4dually)
Brand new user so I hope this is in the correct forum.
On the humidity and enclosure temp readout.....is there a way to change from Deg C to Deg F? I've been trying to search for the part number of the display so I can try to find a datasheet or anything that would give me a hint. Goggle and the search function have failed me. I removed the batteries and didn't see a switch under them. Any ideas if this can be done? I'd much rather have this display in unit I can understand. 😉
Thanks in advance.
Electrical Engineer/Drafter
Postato : 20/01/2023 1:49 pm
Jim
 Jim
(@jim-15)
Utenti
RE: Can I change Enclosure Humidity/Temp Display to Deg F?
Hi 4x4Dually,
I don't know if you found the answer to this, but I figured I would post the answer here also as this was the first post that showed up after doing a web search.
Skybox53 found that you have to take it apart and do a bit of soldering. The link is at Converting temperature LCD module from C to fahrenheit
I haven't tried it yet...maybe I'll just learn Celsius! 🤣
Postato : 05/11/2023 3:15 pm
2 persone hanno apprezzato
4x4dually
(@4x4dually)
Thanks, Jim!!! I just now came back to the forum for some XL issues and saw where you had replied. I appreciate your link and my board was closer to the first image shown but still different from both a tad. I solder jumpered the two pads together and wallah!!! Now it reads F degrees! Still says "C" but it's correct in F.
It's no wonder these meters are dirt cheap. The soldering on them looks like it was done in a basement by someone who can't spell "flux" and wouldn't have the first clue what J-STD-001 is. That PWB is nasty. Makes my eyes twitch! LOL
This is the image that was closest to my device.
Posted by: @jim-15
Hi 4x4Dually,
Postato : 22/08/2024 3:23 pm
