Where is best place to mount camera? Poll is created on Jul 29, 2022
Best place to mount (small) camera
EsotericMaker
(@esotericmaker)
Would like to get people's experiences and preferences with where best to mount a small camera, like a Rasberry PI one. I have tried several options and frankly have not been too satisfied with any of them...
My primary purpose for a camera include mostly for monitoring (automatically with Obico/Spaghetti Detective and manually via remote stream to check on a print).
Secondarily, I may want to create "pretty" timelapses.
Please vote in poll and also add your specific experiences, color commentary, and recommendations if any for printable mounts.
  1. Mounted to fixed Prusa frame
  2. Mounted to Y-carriage
  3. Mounted to X-axis (typically to the X-axis stepper motor)
  4. Mounted to enclosure walls
  5. Mounted to enclosure ceiling
  6. Standalone (not connected directly to printer or enclosure) - e.g., on desk or table
Postato : 29/07/2022 5:07 pm
I tried a camera for a few days because I could.  I took a load of uninteresting, useless pictures.  I removed it.
Postato : 29/07/2022 9:35 pm
RE: Best place to mount (small) camera
I've been pretty happy with a Wyze cam mounted to the frame ( https://www.printables.com/model/73395-slide-in-wyze-cam-v3-prusa-mk3-mount). I have one for each of my printers. I also have x-axis mounted pi cams but I hardly ever use those. I don't care for time lapse movies, I use my cams for remote monitoring.
Postato : 29/07/2022 10:31 pm
EsotericMaker
(@esotericmaker)
Posted by: @fuchsr
In your experience, what makes a frame-mounted camera better for monitoring than an X-axis mounted one.
My challenge with frame-mounted cameras is that I have found that the optimal angle is height-related -- so if I am trying to monitor the current layer for accuracy or for spaghetti etc., then a frame-mounted camera that is correctly oriented for the lower layers, starts losing utility for high prints... which is why I was thinking of an X-axis camera whose height increases in tandem with the Z-axis increase.
But I am just trying to learn from others' experiences...
Postato : 31/07/2022 3:46 am
Roger K
(@roger-k)
This [1] works very well for me. I have a Logitech C615 camera that has a tripod screw mount.  Bracket attaches to the unused screw of the Z-drive, so camera moves to always have the same orientation with the hot end.
[1] https://www.printables.com/model/73963-prusa-c920-camera-mount
Postato : 28/08/2022 1:40 pm
