Anywhere to get a y-splitter adapter for using two part cooling fans?
jeremytodd1
(@jeremytodd1)
So I got a couple of part cooling fans as I want to install this mod on my MK3:
https://www.thingiverse.com/thing:2978427
I realize that I can just splice the wires together, but I would love to be able to just use a y splitter adapter that fits the part cooling fans. I do not have a soldering iron or anything, and I never really have a need for one, so I would hate to have to buy one just for this tiny little project.
I thought that a normal computer fan y-splitter would work but the connection is quite a bit bigger than the part cooling fan's connector.
Does anyone know of a y-splitter adapter that would work with these fans?
Opublikowany : 09/03/2019 9:57 pm
Martin_au
(@martin_au)
Re: Anywhere to get a y-splitter adapter for using two part cooling fans?
You can get some molex 50-57 connectors and make one. That would be the easiest solution, though not cheapest as you’ll need a crimp tool. Useful though, as it means you can also build new cables for filament sensor. I’m redoing cables with silicone wiring for extra durability.
Opublikowany : 09/03/2019 10:06 pm
jeremytodd1
(@jeremytodd1)
Thank you for the suggestion, but I really am just trying to find a y-splitter for this.
Opublikowany : 09/03/2019 10:47 pm
