Test
That looks pretty good. I will test print it Monday night.
I'll be printing this mashup today in ABS and seeing how it fits on my MK3S+. I think it will be pretty close to good. If anyone else wants to try - the pattern is attached. (untested)
Attachment removed
Looks amazing
Looks really good, how are the overhangs with it compared to the stock shroud?
Time will tell
The one I remixed to make this one that fits a MK3S+ has been on one of my printers for a month or so. I do think I see a difference in bridges. I printed a sun-dial last week that had some inch-ish bridges on movable parts (tight tolerances) on the thing that makes the shadow ... (it has a name that I do not know). I never saw that machine make such a clean bridge and I attribute that to this more radial design. With this mashup I am going to have to see how it works on the MK3S+.
I have several bridge-intensive prints that I need to make periodically - now that both machines have the same basic design of part fan shroud attached, I can see if this one needs any fine tuning or not.
@dan-rogers
I finally had a chance to print this new shroud design. The two anchor points are a bit too close together, the right one that just slides in I think needs to be shifted to the right by a mm or so. I could try to hack it in Fusion 360 but Dan, if you would be willing to share the design file? I can squeeze it in by force but it's not great.
