Anyone using the Printed Solid textured sheet?
natehansen66
(@natehansen66)
I needed a couple things from them and figured I'd pick one up. I've never used a textured sheet before. This thing is like 60 grit sandpaper....cleaning with cloth towels and paper towels leaves bit of material on the print surface. I ended up rewashing in the sink then blowing it off with compressed air but that's hardly convenient. How are ya'll cleaning these?
Veröffentlicht : 10/05/2020 1:05 pm
Mitglied
RE: Anyone using the Printed Solid textured sheet?
I have several. I use dawn and water once every 1-2 weeks and IPA between prints.
This print bed is nearly identical if not made by theKKIINNGG.
Thekkiinngg Prusa MK3 /S Double-Sided Textured Pei Powder-Coated Sheet V4
Veröffentlicht : 10/05/2020 1:38 pm
natehansen66
(@natehansen66)
@charles-h13
Ok but what are you using the apply the dawn and IPA? As I said I get bits of cloth or paper towel stuck all over the sheet if I attempt to use those to the point where I need to rewash and blow dry.
Veröffentlicht : 10/05/2020 1:56 pm
Mitglied
@natehansen66
  1. I spray on IPA after each use and wipe it off with a low lint paper towel.  I use either blue shop towels or Viva paper towels.
  2. Once a week, I wash the bed with water and Dawn dishwashing liquid.  I use a standard kitchen sponge.  I dry it with Viva paper towels.
https://www.vivatowels.com/en-us/
Veröffentlicht : 10/05/2020 3:02 pm
natehansen66
(@natehansen66)
@charles-h13
Ah thanks should have thought about shop towels. I'll give that a shot.
Veröffentlicht : 10/05/2020 5:21 pm
