Anyone using the Bondtech LGX Shortcut?
Lynk
 Lynk
(@lynk)
So I recently decided to try and get into printing again. I stopped about 6 months ago due to having constant clogging/skipping issues with my modded MK3S+ after installing the LGX Shortcut. I'm still having nozzle clog issues after about 20 mins of printing any pulling my hair out trying to figure out why. For some history, I've had this problem with 0.2mm and now 0.6mm. I first reset the printer and did the test (passed) then first layer calibration where my Z is offset by -1.430 which gave me what appears to be a nice smooth layer using 'live adjust Z my way'.
When I first heard the dreaded clicking form the extruder gears, I tried decreasing the flow and raising the z a bit but that did not help. I pulled apart the LGX and only found filament buildup in the nozzle itself, to which I cleaned it out as best I could. Keep in mind, I don't think I have a nozzle issue per say, and I also tried a different PLA from Prusa but no different. I ended up buying a new carriage and heated bed thinking it's unlevel in areas causing the flow to be obstructed but have not switched it out yet.
I reached out to Bondtech but they offered only modifying my slicer settings to decrease flow. Dropping from 100 to 80 does nothing but I have not yet tried lower. I really think I'm troubleshooting in a loop here where it's a calibration issue or simple slicer setting I didn't modify properly. My most recent attempt was removing all profiles and adding in the 0.6mm profile.
Anything else i can do to fix this and keep the LGX?
Dieses Thema wurde geändert Vor 3 years von Lynk
Veröffentlicht : 09/07/2023 11:38 pm
Lynk
 Lynk
(@lynk)
Veröffentlicht : 09/07/2023 11:47 pm
Lynk
 Lynk
(@lynk)
RE: Anyone using the Bondtech LGX Shortcut?
I've also check the bed level with the nylock mod and was able to get 0.02 variation.
Veröffentlicht : 09/07/2023 11:50 pm
ColombosCustoms
(@colomboscustoms)
Mitglied
Are you using the Bondtech firmware?
Veröffentlicht : 07/01/2024 5:24 am
Reds2intense
(@reds2intense)
I am using the LGX SC with the Copperhead and am using it with the Custom Bondtech Firmware which to my understanding mainly changes the “stepper settings”.
I also got clogging issues (and dreaded clicking) but my buildup starts in the HeatBreak. This Issue is a bit old but i hope your still happy printing !
Diese r Beitrag wurde geändert Vor 11 months von Reds2intense
Veröffentlicht : 30/04/2025 5:47 pm
McQ
 McQ
(@mcq)
I "upgraded" my Prusa MK3S+ with an LGX Shortcut. Big mistake. It clogs frequently and it is an incredible pain to clear the clog. It's the result of heat creep, which results in the filament melting in the heatbreak, then solidifying into a solid lump. And when I disassemble it and extract the blockage, it has a little flare in it, where there is evidently a space between the feed tube and heatbreak tube. So it may be a manufacturing error, or maybe it's just an innate flaw in the design of the Shortcut. In any case, I would NOT recommend buying one of these. Stick to the standard Mosquito if you want to go with Bondtech.
Veröffentlicht : 07/10/2025 12:28 am
Lynk
 Lynk
(@lynk)
Are you sure you set the steps correctly? I had this same problem until I was told I missed setting the stepping.
Veröffentlicht : 07/10/2025 6:54 am
McQ
 McQ
(@mcq)
stepping?
Veröffentlicht : 07/10/2025 5:04 pm
Lynk
 Lynk
(@lynk)
I added the M350 E16 and saved it with M500.
Veröffentlicht : 07/10/2025 9:43 pm
