Anybody got Arc Welder working with their i3MK3S/S+?
prusanewuser
(@prusanewuser)
Tried it but the resulting prints are much worse than those printed without the plugin. Circular ring became irregular shaped ring. Almost smooth surfaces are no longer smooth.
Napsal : 29/03/2021 2:25 am
RE: Anybody got Arc Welder working with their i3MK3S/S+?
I've got it installed. No perceptible difference in print quality, but files are much smaller, so should transfer over USB faster. I've read that even with G2/G3 enabled in firmware, the command get interpolated back to segments internally, so print quality may not improve on older controllers.
Napsal : 29/03/2021 2:41 am
prusanewuser
(@prusanewuser)
In my case, it deformed my prints badly. What Resolution in MM and Max Arc Radius did you set to? Checking the "overrides relative extruder mode" did not result in any noticeable difference.
Napsal : 29/03/2021 3:18 am
Here's what I'm using:
  • Resolution: 0.05mm
  • Maximum Arc radius: 1000000
  • File processing type: Manual only
I think these are all defaults.
I haven't noticed any differences on either my Prusa i3 Mk3 or Artillery Sidewinder X1 printers other than the reduced file sizes.
Napsal : 29/03/2021 4:57 am
