Alternate Power Supply - Meanwell RSP-320-24
Seite 2 / 2
DanielM
(@danielm)
RE: Alternate Power Supply - Meanwell RSP-320-24
Hello,
And nice job with the PSU replacement, trying to do the same I stumbled on your post. I ordered LRS-350-24 and I want to put it outside the Tukkari enclosure that i installed. The question is from where did you take the power panic circuitry and if you have a schematic of how is connected. I would prefer to keep the original PSU intact if possible as an emergency spare.
Thank you,
Daniel
Veröffentlicht : 11/09/2022 11:10 am
Netpackrat
(@netpackrat)
I used this kit for my Bear build using an LRS-350-24:
https://www.ebay.com/itm/265625301221
They are clone parts, so your mileage may vary.  I found that some of the crimps were poorly done, and needed rework.  It wasn't  initially obvious how some of the wires hooked up, and I couldn't find a wiring diagram but eventually I got it sorted.  There's probably an old thread or two on this forum that may help.
https://www.printables.com/@Netpackrat/models
Veröffentlicht : 11/09/2022 11:43 am
DanielM
(@danielm)
Thank you for the tip, unfortunately probably shipment will cost from US to EU more that the device. However If anyone else is interested I found another alternative on Aliexpress https://www.aliexpress.com/item/32917946244.html
Veröffentlicht : 11/09/2022 11:53 am
DockGuy
(@dockguy)
Mitglied
Rear-facing AC receptacle
If you prefer a rear-facing AC/Mains receptacle, I made this to fit the slim Meanwell PSU a few months ago:
https://www.printables.com/model/237897-meanwell-lrs-350-psu-cover-w-rear-ac-for-prusa-mk3
Veröffentlicht : 12/11/2022 7:51 pm
Seite 2 / 2
