RE: Alternate Power Supply - Meanwell RSP-320-24
Hello,
And nice job with the PSU replacement, trying to do the same I stumbled on your post. I ordered LRS-350-24 and I want to put it outside the Tukkari enclosure that i installed. The question is from where did you take the power panic circuitry and if you have a schematic of how is connected. I would prefer to keep the original PSU intact if possible as an emergency spare.
Thank you,
Daniel
I used this kit for my Bear build using an LRS-350-24:
https://www.ebay.com/itm/265625301221
They are clone parts, so your mileage may vary. I found that some of the crimps were poorly done, and needed rework. It wasn't initially obvious how some of the wires hooked up, and I couldn't find a wiring diagram but eventually I got it sorted. There's probably an old thread or two on this forum that may help.
Thank you for the tip, unfortunately probably shipment will cost from US to EU more that the device. However If anyone else is interested I found another alternative on Aliexpress https://www.aliexpress.com/item/32917946244.html .
Rear-facing AC receptacle
If you prefer a rear-facing AC/Mains receptacle, I made this to fit the slim Meanwell PSU a few months ago:
https://www.printables.com/model/237897-meanwell-lrs-350-psu-cover-w-rear-ac-for-prusa-mk3
