Add a Z-limit Switch?
I have an old MK3 that I want to repurpose as a motion control system for a camera for work. I only want to use the XZ plane and plan on re-framing everything. My only issue is Z-homing, since the printer uses the pinda probe. I’d like to add a physical z-limit switch to use instead. Does anyone know if the Einsy board has physical support for one? I’m already assuming firmware modifications. Thanks.
Opublikowany : 06/01/2026 4:24 am
