Turn off cooling fan when print is canceled
Falcon
(@falcon)
I just ran into this as a print detached, when you select stop print from the LCD control, the bed and hot end get set to off/0, but the cooling fan is left running. It can be stopped by going into Menu > Settings > temperature > fan speed and turning it to zero, but why is it left running when the print is canceled?
Is there a better place than here to report this? I'm not quite sure it's a bug, but it should at least be discussed as to if this is the correct behavior.
Opublikowany : 24/10/2016 2:55 am
JohnOCFII
(@johnocfii)
Re: Turn off cooling fan when print is canceled
Which fan? Which firmware are you using? Based on the release notes, this might be fixed in 3.0.9, released this past week: https://github.com/prusa3d/Prusa-Firmware/releases/tag/3.0.9
Opublikowany : 24/10/2016 4:05 am
Falcon
(@falcon)
I'll upgrade to 3.0.9 tonight and see if it is.
Opublikowany : 24/10/2016 6:19 pm
Falcon
(@falcon)
This is indeed fixed in 3.0.9.
Opublikowany : 25/11/2016 4:36 pm
