Slicer raft settings
mathew.p
(@mathew-p)
Hello,
I am having limited success with rafts in slicer.
Although blurry you can see the first layer is not very complete.
I am using the default settings for the rafts.
Has anyone come up with any good settings for the rafts?
Also has anyone come up with good settings for cura?
Posted : 07/01/2016 4:12 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Slicer raft settings
Hi Matthew
For me, the default raft settings in Cura have been fine. I mostly use KISSlicer thought but the defaults in that needed quite a bit of tweaking to get right. The main problem was insufficient air gap between raft and first layer. In your case, you might want to try reducing that.
Peter
Posted : 07/01/2016 9:49 am
Josef Průša
(@josef-prusa)
Member Admin
Hi Matthew
You should look at Contact Z distance and Pattern spacing setting in Slic3r. When you hover over those options you will get a tooltip how to set them.
Founder and owner / Majitel a zakladatel
Posted : 24/01/2016 7:54 pm
