Slic3r Prusa Edition (Notepad Gcode Question)
JJ3DPrinter
(@jj3dprinter)
I'm not sure why now when I slice my model and export the Slic3r Gcode that it goes into paragraph form instead of an individual lines for each command. I noticed the previous version of slic3r prusa edition was doing this as well 1.35.12 and it's still doing this in version 1.36.2. This makes it harder to read so I'm hoping someone can point me to a software setting to fix this or knows why this is the case.
Gcode in Prusa Slic3r 1.34.1 (Optimal)
Gcode in Prusa Slic3r 1.36.2 and 1.35 version (Not optimal)
Postato : 01/08/2017 10:48 pm
Knickohr
(@knickohr)
Utenti Moderator
Re: Slic3r Prusa Edition (Notepad Gcode Question)
Open with wordpad, not with notepad 😉
CR/LF ist exchanged or one is missing. This is an typical Linux-problem, but also persistant at windows programs.
Thomas
Postato : 02/08/2017 9:23 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Or Notepad++
Peter
Postato : 02/08/2017 10:00 am
JJ3DPrinter
(@jj3dprinter)
Thanks for the tip guys. MS Word was taking way to long to open long gcode files since notepad didn't seem to work anymore. I went with notepad ++ and it makes checking the gcode so much quicker.
Postato : 02/08/2017 7:25 pm
PJR
 PJR
(@pjr)
Yeah, notepad is also great for amending the firmware...
But Wordpad in not Word; it's a simple version (mainly RTF) and is usually supplied with most Windows versions.
Peter
Postato : 02/08/2017 9:54 pm
