Slic3r PE MM Feed Rate setting issue
Hello,
I have recently upgrade to a MM setup and I've been having a few issues completing a print. I've worked most of them out, thanks to this forum. My current problem I believe is that I am printing too fast and the extruder is getting jammed up. So I decided to use the same gcode but turn the feed rate down on the front of the printer.
Here lies my issue. Every time there is a tool change in my gcode, there is a M220 S100 command that follows. Which means feed rate is reset to (I'm assuming the set value) 100 and renders the function almost useless. I'm currently using version 1.35.5.16. Is there something in Slic3r that can prevent this from being added every tool change?
Thanks
Re: Slic3r PE MM Feed Rate setting issue
It needs to be there on every tool change simply to ensure that the tower is printed at the correct rates and the load/unload are carried out with the correct speed.
You will have to change the print speed of the model within the slicer.
Peter
