Slic3r gcode errors for multiple prints
Steve
(@steve-10)
First off, I'm loving my new Mk2.
Now to an issue, I use Slic3r, latest version, latest config bundle, 3.0.05 firmware.
When I slice one of these little brackets from Thingiverse: http://www.thingiverse.com/thing:692760
It prints fine. When I add 4 more parts to the plater, the resulting print stops at 10mm ( and not 15) z height and I end up with 2/3 of a print. Printer keeps running, heated bed and nozzle temps stay on as programmed, printhead stops. I check the gcode with the online checker, and it looks like the code is just stops at 10mm and not 15....which is clearly not right.
Any one else seen this and know of a fix?
Best,
Steve
Opublikowany : 07/08/2016 2:18 pm
richard.l
(@richard-l)
Member Moderator
Re: Slic3r gcode errors for multiple prints
Are you printing from the SD card? I have seen where the file hasn't been saved completely before removing the SD card.
Opublikowany : 07/08/2016 2:31 pm
christophe.p
(@christophe-p)
Member Moderator
Hi Stephen,
I just tried to slice a pack of 5 of this stl, and the gcode is generated properly.
Can you publish your gcode file to try to understand better ?
I'm like Jon Snow, I know nothing.
Opublikowany : 07/08/2016 10:17 pm
Steve
(@steve-10)
Thanks for the replies, I think the answer was pulling out the card before it was finished, just checked it on another computer and it looks right.
I really appreciate the community spirit of this forum. None of this is all that easy, and having members that hep makes all the difference between good and great products.
Very best,
Steve
Opublikowany : 08/08/2016 9:44 pm
