Slic3r 1.37.2 Prusa Edition 64bit crashes at send to printer
Spaceman
(@spaceman)
With the driver package 1.9.2 slic3r version 1.37.2 got installed on my computer. I have been using send to printer since about 9 month with previous versions without problems. My printer connect test completes successfull. I'm using OctoPI with my original PRUSA i3 MK2.
It crashes every time. Export G-Code works without problems. I have also tried objects that worked fine in the past. It still crashes.
Regards,
Bernd
Napsal : 10/12/2017 4:14 pm
maxx78
(@maxx78)
Re: Slic3r 1.37.2 Prusa Edition 64bit crashes at send to printer
i do have this behavior sometimes, but i can't find the issue.
I think if press "slice now" first and than "send to printer" it does not crash.
Napsal : 12/12/2017 12:53 pm
michael.n5
(@michael-n5)
same here ... 64bit is slow/unusable/crashes
BUT
Slic3r 1.37.2 Prusa Edition 32bit works fine
just tried Slic3r 1.38.3 Prusa Edition 32bit works OK but doesn't have all the features
however 64bit version crashes or hangs computer
Needs sorting.
Napsal : 13/12/2017 2:12 pm
devilhunter
(@devilhunter)
Mine started crashing a few Slic3r versions ago.
Found out why this happens.
If there is a special character in the first STL file name, like the german ü like in für, it crashes at exporting to octoprint. with other special characters as well.
workaround:
- rename stls before importing them
or
- export to desktop, get rid of special chars, then drag to octoprint window
Napsal : 13/12/2017 9:03 pm
maxx78
(@maxx78)
OMG... are we still in the last century ? 😯
Napsal : 14/12/2017 12:52 pm
tobias.k3
(@tobias-k3)
I have the same issue sometimes.
It's ridiculous, that this is caused by "special" characters. 👿
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
Napsal : 15/12/2017 1:51 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
The OctoPrint crashing issue on non-ASCII characters in the file name will be fixed in the next release, which is coming this Christmas.
If you have any other issue with Slic3r, please create a github issue:
https://github.com/prusa3d/slic3r/issues
Thank you,
Vojtech
Napsal : 21/12/2017 7:31 pm
