Simplifying the workflow : ColorPrint with ZHop
Shree Kumar
(@shree-kumar)
I use ColorPrint a lot. If I enable ZHop, then it does not work with the ColorPrint app.
Identifying the layers is a simple task without ZHop. With ZHop, it becomes much more difficult. Enabling the "Verbose G-code" option annotates the generated g-code with useful comments. This makes it very easy to identify the layer changes too; these are annotated with text like "move to next layer".
I have written a small filter script in Python. This processes the generated g-code & then prompts the user for layer change info. It then inserts the M600 gcode at the appropriate place.
With this script, my ColorPrint workflow adds two simple steps:
  • Enable "verbose g code" option
  • Set the filter script name under "Print Settings | Output options | Post processing scripts"
  • What does your ColorPrint workflow look like ? I am trying to see if this can be simplified further.
    PS: If anybody is interested in the script, I can share it. I am looking to post it online (possibly Github) after some cleanup.
    Respondido : 05/09/2016 6:34 pm
    David T.
    (@david-t)
    Re: Simplifying the workflow : ColorPrint with ZHop
    Simple. I generate gcode with ZHop enabled, then open it in favorite text editor, find first G1 Zx.xx line with required Z value (I usually set up the Slic3r so actual layer plus ZHop value doesn't give next layer Z value), insert M600 before this line manually, save, print and done.
    Respondido : 05/09/2016 6:48 pm
    PJR
     PJR
    (@pjr)
    Antient Member Moderator
    I do the same as David, except that I also remove the following line of GCode which is a prime after the previous retract.
    Removing the prime prevents a blob being printed on restart.
    Peter
    Respondido : 05/09/2016 6:57 pm
    Shree Kumar
    (@shree-kumar)
    Clever trick ! What's the typical ZHop value you use ?
    Peter
    My script does this too; I missed mentioning this detail.
    Respondido : 06/09/2016 5:19 am
    David T.
    (@david-t)
    It depends. Usualy something between 0.15 and 0.25, exceptionally up to 0.45. Most usually 0.22mm.
    Respondido : 06/09/2016 9:10 am
    miferr
    (@miferr)
    I'd like to understand this, as I'd like to change colors with Z-hop.
    Here is a snippet of code. (I added the "verbose g-code" to help--thanks for the tip!) I'd like Z 2.55 to be the first layer with the new color. How would I change it?
    G1 X119.249 Y98.666 E-0.28572 ; wipe and retract
    G1 E-0.51428 F2100.00000 ; retract
    G1 Z2.500 F7200.000 ; lift Z
    G1 Z2.550 F7200.000 ; move to next layer (12)
    G1 Z2.700 F7200.000 ; lift Z
    G1 X127.000 Y97.084 F7200.000 ; move to first perimeter point
    G1 Z2.550 F7200.000 ; restore layer Z
    G1 E0.80000 F2100.00000 ; unretract
    M204 S800 ; adjust acceleration
    G1 F900.000
    My understanding is I would insert M600 after the "move to next layer (12)". And what do I do to remove the blob? Remove the whole line with the "unretract"? Would the following be correct?
    M600
    G1 F900.000
    Respondido : 04/10/2016 2:08 pm
    PJR
     PJR
    (@pjr)
    Yeah, that works, but personally I would insert the M600 here:
    M600
    Peter
    Respondido : 04/10/2016 2:18 pm
    David T.
    (@david-t)
    I usually insert M600 before moving to next layer. Printer finishes previous layer, then do the "change filament" stuff, then moves to next layer and goes with new color. I don't experience any blobs, I just catch (by hand) the string washed out during filament change and don't let it be dragged into printing area.
    Respondido : 04/10/2016 2:19 pm
    miferr
    (@miferr)
    Thanks, I can't wait to try it! Great topic, Shree! I like the idea of using another workflow to do the color change. The ColorPrint tool is kind of a black box, and it is not obvious to know if I've done it correctly. I didn't realize the code for the color change was so simple.
    Respondido : 04/10/2016 3:36 pm
    Shree Kumar
    (@shree-kumar)
    I can share this with you in a few days. What OS are you running (Windows/Linux or something else) ? My script has a dependency on python & some packages. Would you be OK installing them additionally to get this to work ?
    Thanks
    -- Shree
    Respondido : 05/10/2016 9:17 am
    miferr
    (@miferr)
    I'm running Windows 10. I don't mind running Python at all; I've done some Python programming before, though it's been a while. I don't have it installed on this machine but I easily could.
    I tried the g-code changes on a file last night with great success! I didn't realize the blob was caused by code so I was printing extra structures to the outside of the print to get it to start off the print first. This is much better.
    Respondido : 05/10/2016 3:06 pm
    Shree Kumar
    (@shree-kumar)
    I have kept my script at
    https://github.com/shreekumar3d/gcode-proc/blob/master/filament-change-at-Z.py
    Setup & usage instructions are on top of the script. The script throws up a dialog box with all layer numbers. Select the layers that you need. If you need only one filament change (and find the process of scrolling & selecting the layer tedious), then you can edit the code and use
    changeLayers = getSingleFilamentChange(layerZ)
    For my day to day usage, I have enabled the required custom g-code settings & saved it in my printer profile. I have also created a"Print Setting" with the post processing script.
    Respondido : 08/10/2016 8:42 am
