Rumours after update
Franco
(@franco)
Hi, after installing update, the printer and become more noisy, and normal?
I asked also that maintenance should be done on the bearings and extruder.
bearing goes well with Svitol lubricant.
Regards
Franco
Opublikowany : 17/03/2016 11:13 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Rumours after update
Hi Franco
I presume you are referring to the firmware V2.2.3?
That version has new settings for "Quiet" and "High Power" modes. The quiet mode is the same as before and the high power mode is to be used is you have problems with either the X or Y axis shifting during a print.
Peter
Opublikowany : 17/03/2016 11:17 am
Franco
(@franco)
Hello Peter, the firmware 2.2.4, I saw that I had the power and not so silence ...
I try again and let you know ...
For bearing maintenance do I do?
Ciao Franco
Opublikowany : 17/03/2016 2:09 pm
PJR
 PJR
(@pjr)
Hi Franco
Regarding the bearings, I think it depends on your environment.
For me, I do not grease the bearings; my room is very dusty and the dust combines with grease to become a very abrasive mix, thereby waering out the bearings very quickly.
Peter
EDIT: I see the difference; FW 2.2.4 includes Italian... No operational changes.
Opublikowany : 17/03/2016 2:33 pm
