Repetier Host Question
hagensieker
(@hagensieker)
Just got my i3 Mk2, built it and it worked first time with no problems. Printing from SD is going well.
I have another rep-rap kit that I use repetier and slic3r on and would like to continue doing that.
Set my Port and baud rate to 115200 and can connect. Right after that I get this:
> 11:16:02 PM: N1 M110 *2
< 11:16:02 PM: echo:echo: Last Updated: Feb 14 2017 15:35:19 | Author: (none, default config)
> 11:16:02 PM: N2 M110 *1
< 11:16:02 PM: Compiled: Feb 14 2017
> 11:16:02 PM: N3 M115 *5
< 11:16:02 PM: echo: Free Memory: 2670 PlannerBufferBytes: 1280
< 11:16:02 PM: echo:Hardcoded Default Settings Loaded
< 11:16:03 PM: Invalid M code.
> 11:16:03 PM: N5 M111 S6 *66
< 11:16:04 PM: Invalid M code.
> 11:16:04 PM: N6 M111 S6 *65
I haven't tried to print anything but the extruder and fans are working and it seems to hit home. Not sure if I have a problem or not here.
Opublikowany : 25/02/2017 5:20 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Repetier Host Question
M111 (Set Debug Level) is not implemented in the Prusa/Marlin firmware.
In theory, it should not be doing any harm...)
Peter
Opublikowany : 27/02/2017 4:05 pm
