[Geschlossen] Prusa Slicer custom temp
Gavin
(@gavin)
I have purchased white ABS filment that requires print temp to be set between 220 and 240, I have tried using a standard ABS profile in Slicer however the print temp is 255 and as the print continues there are black distorted blotches coming out in the middle of the white print, I do not have this happening with PLA. I assume the temp is too high ? How would I set a custom ABS print profile to change the temp in the Prusa Slicer to a lower setting ?
thanks
Gavin
Veröffentlicht : 16/09/2019 10:12 am
RE: Prusa Slicer custom temp
Filament tab, set desired print temp, save as.
Veröffentlicht : 16/09/2019 1:45 pm
