prusa control win7
hola buenas tardes, soy emilio de cordoba republica argentina. vengo con un problema de instalacion del prusa control. resulta que poseo windows 7 starter 32bits y al ejecutar prusa control windows me dice que debo verificar mi sistema. si es 32 bits o 64 bits.
existe una version para 32 bits compatible con mi windows ?
muchas gracias
PJR - Moved to English forum - Google translate:
Hello good afternoon, I'm emilio from cordoba republic argentina I come with a prusa control installation problem. It turns out that I have windows 7 starter 32bits and when I run prusa control windows it tells me to check my system. Whether it is 32-bit or 64-bit.
Is there a 32-bit version compatible with my windows?
thank you very much
Opublikowany : 15/08/2017 6:49 pm
