Prusa Control stalls out during gcode export
MakingThingsCLT
(@makingthingsclt)
I just tried to import a gcode file from Slic3r into Prusa Control to make a color change edit. It's a very small file, with two thin pieces that are only 1mm thick. The color change happens at 0.8mm. When I try to save the gcode, Prusa Control stalls at 75% completion. I can open the new gcode file in Notebook++ even while it's "working" and see that it's mostly there, but stops outputting lines of code before the end. Anyone else experience this?
Opublikowany : 27/09/2017 12:50 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Re: Prusa Control stalls out during gcode export
https://github.com/prusa3d/prusacontrol/issues
Opublikowany : 04/10/2017 2:39 pm
