Prusa Control No Response
Ramón Fürst
(@ramon-furst)
Hey there about a week ago i had to restore my computer after a trojaner, after that Prusa Control wont work anymore.... I tried everything i deinstalled the Software, and reinstalled it the oldd and the new version. Deleted every file Prusa Control ever created and after doing all that it still wont work. I need help pls 👿 👿 👿 👿
Posted : 19/09/2017 7:55 pm
MechLink
(@mechlink)
Re: Prusa Control No Response
Hi. I had similar issue with it after windows did an update, to fix it I had to in-install it and delete the folders as well as run a reg-cleaner then rebooted my PC and then I re-installed it and it works fine now.
also I did have on my other PC it wouldn't launch the Prusda control after I update it to newer version with the shortcut I had on my desktop but the shortcut in the start menu worked just fine.
you can also check and make sure your OS is up to date,
I know some software needs some of the updates to run correctly, like on windows the
.NET Framework version can cause issues.
without seeing an error or something its hard for me to say but if you still have issues contact Prusa they seem to have a good staff for this stuff.
See my stuff at
https://www.printables.com/@MechLink
https://www.myminifactory.com/users/MechLink
Posted : 22/09/2017 10:09 pm
