Problems cutting in slic3r
prusayo
(@prusayo)
I am using slic3r 1.30.0.25-prusa3d-release-candidate_1_3-win64 on Win 10 and when I cut, if I enter a number for Z, the cursor is placed behind the number such that if I enter a new number it goes behind the first number. For example, if I enter 54, it will be entered as 45. I can use arrow key to move cursor over though.
If I scale an object higher, and attempt a cut such that the pieces won't be able to fit, program hangs. For example:
http://www.thingiverse.com/thing:308335
T-RexSkull_Skull.stl
Scale 175%
Attempt cut, hangs (not responding).
Opublikowany : 10/07/2016 6:03 pm
andrew.m6
(@andrew-m6)
Re: Problems cutting in slic3r
did you ever find a fix? i get the same thing whenever i cut a object the program freezes and i get not responding.
when not cutting the program freezes 20 % of the time
Opublikowany : 13/11/2016 4:11 am
prusayo
(@prusayo)
Nope. Still happens, but I have other things to worry about, this is relatively minor.
Opublikowany : 13/11/2016 6:19 am
