Prints disappearing
Almightyeragon
(@almightyeragon)
Prints disappearing
I have been using PrusaControl to set up prints I got online. It shows the print i want and i add the supports and print it. But I've had several prints where large portions of it are replaced with the support scaffolding. I had a figure of a knight and when it was done printing he was a head, right arm and shield floating over a platform. I have printed other ones successfully, so is this PrusaControls fault?
Veröffentlicht : 15/01/2018 9:44 pm
Greybeard3D
(@greybeard3d)
Re: Prints disappearing
I've had this problem happen in Slic3r. You need to adjust something to get it to recompute the file, then adjust it back. Like the layer height.
Veröffentlicht : 16/01/2018 7:46 pm
Okami 359
(@okami-359)
There may be an issue with the model as well. If there are multiple shells it might be causing issues. Try running the 3d file through netfab first and see if it still happens. https://service.netfabb.com/login.php
Veröffentlicht : 17/01/2018 1:43 am
