Pausing a Print
I'd like to have a more smart "pause print".
Currently, the noozle stops where it is when printing. It would be good to do some movement (such has 10 mm higher) to avoid the plastic to drop during the "pause".
When restarting I can then clean the noozle and the print can restart lowering to the correct level.
I understand that this is not optimal, but it's probably better than now...
Napsal : 23/08/2016 10:27 am
Re: Pausing a Print
A good extruder retraction can also help some with the ooze.
Napsal : 24/08/2016 1:49 am
Re: Pausing a Print
Actually I don't use "Pause print" at all. I use "Change filament" instead. Extruder then moves up a little and moves outside printing area.
It would be nice if "Pause print" command behaved the same way except unloading the filament.
Napsal : 24/08/2016 8:22 am
