Octoprint Scripts
GertL
(@gertl)
Octoprint Scripts
Finally came to install Octoprint.
So far so good 🙂
Printing a Raspberry PI mount from it now.
Can someone share whatever scripts you are using ?
The ones that gone under GCODE Scripts.
Gert
Napsal : 25/06/2017 3:51 pm
Carsten
(@carsten-2)
Re: Octoprint Scripts
Before start;
; PID tuning
M301 P15.27 I0.98 D59.42
;beep & message to remind me to check for nozzle and old intro line
M300 S1 P200
M117 Remove Intro Line!
After Print:
M117 Octoprint ready.
Abort print:
G91; Set to Relative position
G1 E-1 F300; retract the filament a bit before lifting the nozzle
G0 Z15; move z axis up 15
G28 X; home X axis
G1 Y150 F5000; move part out for inspection
G90; Set to Absolute position
;disable all heaters
{% snippet 'disable_hotends' %}
{% snippet 'disable_bed' %}
;disable fan
M106 S0
; disable motors
M84 ; which one?
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Napsal : 25/06/2017 6:49 pm
GertL
(@gertl)
Thanks Carsten
M117 i get, just a message, right ?
What is the reason for doing the PID from Octoprint? I have that in my GCODE.
Also, i get a Sleep message when printing with my gcode from Octoprint, do you have a clue why?
My start code in S3D
M301 P18.00 I1.47 D54.92 ; PID 240 Degrees
G0 Z60 ; get head above bed to keep it cool
M140 S[bed1_temperature] ; this will take the layer 1 temperature for bed 0
M190 S[bed1_temperature] ; wait for bed temp
M104 S[extruder0_temperature] T0 ; this will take the layer 1 temperature for extruder 0
M109 S[extruder0_temperature] T0 ; wait for extruder temp
M300 S440 P500 ; Beep 0.5 Sec
G4 S10 ; Wait 10 Sec. Remove ooze filament.
G80 ; mesh bed leveling
G1 Y-3.0 F1000.0 ; go outside printing area
Gert
Napsal : 25/06/2017 7:44 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Faulty firmware - it happens when not printing from SD card and overrides all the Octoprint/slicer messages...
Peter
Napsal : 25/06/2017 8:01 pm
GertL
(@gertl)
Ok, I'm on 3.0.10, is this fixed in 3.0.11 what you know of?
Gert
Napsal : 25/06/2017 8:44 pm
PJR
 PJR
(@pjr)
I don't think so, there was something implemented in 3.0.12-RC1 (for MM) I believe, but it still does exactly the same for me.
For me, when printing, that 4th line should be left alone for messages I want to display and not be overridden by useless firmware messages.
Peter
Napsal : 25/06/2017 8:57 pm
GertL
(@gertl)
Can confirm, 3.0.11 dosent fix it.
Thanks Peter, i came around to do the upgrade finally anyway 🙂
Gert
Napsal : 25/06/2017 9:23 pm
