Octoprint not liking new profiles?
Intrudermax
(@intrudermax)
So I downloaded 2.0 of the drivers and loaded the new profiles into slic3r. Now, when I send the files to Octoprint, either straight from Slic3r or drag-and-drop into the octoprint interface, the printer goes through its normal bed calibration, does the nozzle clean at the front of the bed and....stops. Looking at the Octoprint terminal I see the following:
Send: N16 M900 K{if printer_preset=="Original Prusa i3 MK2 MultiMaterial"}200{elsif printer_preset=="Original Prusa i3 MK2 MM Single Mode"}200{else}30{endif}*11
Recv: Error:No Line Number with checksum, Last Line: 15
Recv: Error:No Checksum with line number, Last Line: 15
Recv: Resend: 16
Recv: ok
It does this several times. I then have to reset at the display to get any response from the printer. If I run an older file through Octoprint, either stored on the raspi or on the SD card, it works fine. If I load the file directly onto the SD card using my computer it works fine. So, Octoprint isn't liking something that the new profiles are doing.
I am running waldemar's modified firmware, but that should, in theory, affect only the bed leveling.
Any ideas?
Veröffentlicht : 10/12/2017 4:15 pm
Intrudermax
(@intrudermax)
Re: Octoprint not liking new profiles?
The problem gcode looks to only be in the start gcode for the Prusa-provided filament settings.
Veröffentlicht : 10/12/2017 4:18 pm
AJS
 AJS
(@ajs)
https://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/printer-stops-mid-print--t3827-s10.html#p48832
Veröffentlicht : 10/12/2017 5:16 pm
Intrudermax
(@intrudermax)
Thanks, Aaron. Not sure if it is the same thing. I've been running everything just fine up until loading the new profiles. I will try a print using one of my own filament profiles and not use the Prusa-generated ones and see what happens. If it works correctly, that pretty much points to the startup gcode in the filaments profiles for the Prusa filament.
Veröffentlicht : 10/12/2017 5:46 pm
AJS
 AJS
(@ajs)
If you did a firmware change at the same time, this is likely it. Octoprint really does not care what it sends to the USB - it just send the file.
I have been running the new profiles and firmware with Octoprint with no issues. (But I use the MMU profiles). But I did do the M110 fix.
Veröffentlicht : 10/12/2017 7:40 pm
Intrudermax
(@intrudermax)
I updated the firmware a couple of weeks ago, so that doesn't appear to be it.
I sliced a file using my own filament profile and it worked just fine. There seems to be some incompatibility between the start code in the Prusa filaments and Octoprint. I am not using the MMU.
Veröffentlicht : 10/12/2017 8:26 pm
kevin.r5
(@kevin-r5)
It looks like you're using the profile for an MK3 printer.
The code from your first post:
This code isn't in either of the config bundles for the MK2 (mk2_Slic3r_prusa3d_1_9_2.ini or mk2mm_Slic3r_prusa3d_1_9_2.ini). It is only in the MK3 config bundle (mk3_Slic3r_prusa3d_2_0_0.ini).
The config bundles for the MK2 haven't changed between V1.9.2 and V2.0.0 (compared them and they are identical).
-Kevin
Veröffentlicht : 10/12/2017 11:11 pm
Intrudermax
(@intrudermax)
That may well be it. I didn’t realize that 2.0 was for the mk3 only. I selected the mk2 profile, but the code is in the filament profiles, not the printer profile.
Live and learn I suppose.
Thanks for researching.
Veröffentlicht : 11/12/2017 11:47 pm
