[Closed] Merging Changes
gkas
 gkas
(@gkas)
Merging Changes
I've been using the bobstro Prusaslicer changes mentioned in a previous forum post to improve release of supports.
0.25mm z distance.
75% xy distance.
3mm support spacing.
4 interface layers.
0.2mm interface layer spacing.
 These work great for me. I keep entering these changes manually whenever I need supports. Is there a way to save these changes and then import them into a slicer profile when I need them?
Napsal : 08/07/2020 8:49 pm
RE: Merging Changes
Just set your settings under Print Settings as you like them, then click the little diskette icon next to the profile name. Give it a custom name and you'll create a custom profile you can use going forward.
Napsal : 08/07/2020 9:46 pm
gkas
 gkas
(@gkas)
RE: Merging Changes
@bobstro
Thanks. This is what I have been doing. I've just been lazy and figured that I could get around having to manually enter them into every profile... 😀 😀
P.S. Great changes, worth the effort.
Napsal : 08/07/2020 10:19 pm
RE: Merging Changes
Thanks.  That will stop me from typing ti every time.
Napsal : 09/07/2020 2:58 am
