Loading filament annoyance
sean.t
(@sean-t)
Does anyone have any tips for this?
If I want to load filament in and the nozzle is in its start position (very close to the bed), this means that the filament gets caught between the nozzle and bed and turns into a big-ish blob.
I have to calibrate Z so that the nozzle rises and I can clean the nozzle.
How can I sort it so the nozzle moves up when loading filament?
Ta
EDIT: PUTTING IN CORRECT TOPIC 🙄
Publié : 20/01/2018 10:40 pm
spark
(@spark)
Re: Loading filament annoyance
The easiest way is to use Long Press of knob. This will trigger Z-adjust shortcut where you can do so at any time. Best not to tempt fate by using during print though. I also use home rolled G-code. I have one for each filament type I use. Maybe you can mod to your liking.
Below code is for PLA. Also please note, I have extruder setting code in there. You can comment out or use your own settings.
As always, use at your own risk.
; Load PLA by Stephan Park for Original Prusa MK2
; Feed rate is tuned to specific printer, please correct prior to using.
M107 ; Part fan off
M92 E166.9 ; Set extrusion rate
M500 ; Store/overwrite extrusion to EPPROM
M1 Please load PLA, click to continue.
M117 Precautionary Homing ; Message LCD
M83 ; extruder relative mode
G0 Z5 ; schooch up to avoid possible bed during homing
G28 W ; Home without Mesh Level
G4 ; wait
M117 Convenience Move ; Message LCD
M82 ; Coordinate system to Absolute
G0 X125 Z50
M104 S215 ; set extruder temp
M109 S215 ; wait for extruder temp
M701 ; Load filament command
G4 ; wait
M104 S0 ; turn off temperature
M84 ; disable motors
M117 Loaded and ready! ; Message LCD
M300 S1046.5 P100 ; Play C6
M300 S1174.7 P100 ; Play D6
M300 S1318.5 P100 ; Play E6
M300 S1396.9 P100 ; Play F6
MK2S kit owner since 8/15/2017
Publié : 21/01/2018 3:33 am
spark
(@spark)
Script error. Confused extruder relative with positional relative. Corrected below.
M107 ; Part fan off
M500 ; Store extrusion to EEPROM
M1 Please load PLA.
G91 ; set position to relative
G90 ; set positioning to absolute
G4 ; wait
G0 X125 Z50
M701 ; Load filmanet
G4 ; wait
M117 Loaded! Printer Ready. ; Message LCD
Publié : 24/01/2018 6:13 am
