Increase of print speed
FAS Converting Machinery AB
(@fas-converting-machinery-ab)
I'm trying to increase the print speed of my Prusa MK2S with E3D Titan extruder from 50mm / s to 100mm / s and this is what I got (see attached image). I only changed the print speed in S3D but I must obviously change some other parameters as well. Can anyone please help me point out which parameters I should change. My goal is to go even higher in speed (150+) with the MK3 that should pop up any day now.
Veröffentlicht : 17/01/2018 7:26 am
Milos V.
(@milos-v)
Re: Increase of print speed
In Slic3r there are new presets for 100mms speed with this advance function. I have to say that the speed increase is really big on MK2.
Hard to say what presets you have for S3D, but just increasing the speed will not make it. Try Slic3r.
Also you are testing the high speed on benchy model, which is full of typical difficulities. I do not think that you can print overhangs with such a speed. Simply some print phase do need more time to cool down.
Milos.
Veröffentlicht : 17/01/2018 6:37 pm
