How to remove overhang perimeter in PrusaSlicer
Hey guys,
I would like to remove the overhang perimeters in my prints as can be seen in the picture. I would appreciate some piece of advice.
Greetings
RE: How to remove overhang perimeter in PrusaSlicer
Hi @tlp could you solve your problem? I'm sort of stuck with the same problem. Maybe you can push me in the right direction how to influence the overhang perimeter thickness?
Thanks a lot, any help is appreciated!
@freiheitsgrad
unfortunately I haven't come to any solution yet 🙁
Thanks for the reply. I've already posted the same question in the 'official' software forum, awaiting release from the Mod. Maybe you like to check any replies here: https://forum.prusa3d.com/forum/prusaslicer/editing-thickness-of-overhang-perimeters/
Cheers, Lars.
You may disable "detect bridging perimeters". This will work if just perimeters are extruded over the supports, which seems to be your case.
@bubnikv
Thanks a lot, I will test that.
