how to change retraction in slic3r for just 1 filament?
[Closed] how to change retraction in slic3r for just 1 filament?
Enlightx
(@enlightx)
hi guys
is it possible to change retraction length and speed for just one filament instead of all profiles?
retraction seems to be under printer settings and not filament settings
Posted : 17/03/2018 1:36 pm
Zingabopp
(@zingabopp)
Re: how to change retraction in slic3r for just 1 filament?
If you use firmware retraction, you can set the speed/length/zhop in the filament's gcode. You can't use wipe or coast though.
Posted : 18/03/2018 1:21 am
Is this on MMU?
on the MMU, within the Printer Settings window, you can set different retractions for each extruder!
Posted : 18/03/2018 1:25 am
