Gcode for speaker?
Mark Shurtleff
(@mark-shurtleff)
Gcode for speaker?
Does the firmware implement any gcode for sounding the speaker on the LCD module? I would like to be able to end a print job with a nice "beep beep beep" ...
Opublikowany : 21/04/2016 8:02 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Gcode for speaker?
Hi Mark
M300 Sxx Pyy
Where xx is frequency and yy is milliseconds.
Peter
Opublikowany : 21/04/2016 8:06 pm
renegadesk
(@renegadesk)
Mark,
When printer is finisher printing it plays ghost busters for me. I know for sure it is printer and not random beep. (I dont have nearby)
This is my whole end script.
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
G28 X0 ; home X axis
M84 ; disable motors
M300 S987 P133 ; ghost busters
M300 S987 P133
M300 S2489 P267
M300 S987 P267
M300 S2217 P267
M300 S880 P267
M300 S0 P1071
M300 S987 P133
M300 S987 P133
M300 S987 P133
M300 S987 P133
M300 S880 P267
M300 S987 P267
M300 S0 P1071
It might help you. 😀 But you need latest firmware.
Opublikowany : 23/04/2016 8:31 pm
Mark Shurtleff
(@mark-shurtleff)
That's cute, but a little too much for me, given the speaker's inability to do much more than squawk. I'll stick with a nice triple-beep, thanks. 🙂
One thing I noticed when I added to the stock end script is that using G20 X0 to home the x-axis brings up the "Do you want to auto-level the z-axis" routine. Here's what I ended up using:
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
G91 ; use relative coordinates
G1 Z0.6 F5000 ; lift nozzle 0.6mm
G1 X0.2 Y185 ; move x to left and carriage forward
M117 JOB COMPLETED
M300 S1200 P400 ; beep three times
M300 S0 P400
M300 S1200 P400
M300 S0 P400
M300 S1200 P400
M300 S0 P400
M107 ; turn off fan
I ended up in the Reprap Wiki and found the M117 code, which added a nice touch.
Opublikowany : 02/05/2016 5:39 am
renegadesk
(@renegadesk)
Mark,
Actually as you can see the tones changes as Peter told you:
Hi Mark
M300 Sxx Pyy
Peter.
It looks long but you paste it there once and its ok, It actually sound pretty accurate to be honest.
Opublikowany : 06/05/2016 1:13 am
Mark Shurtleff
(@mark-shurtleff)
Never said the frequencies weren't being produced. Peter's 'tune' is, to me, painful to listen to - hence my comment about the speaker. 🙂
Opublikowany : 10/05/2016 2:33 am
PJR
 PJR
(@pjr)
Mark, I never presented any "tune", only the M300 GCode line.
Peter
Opublikowany : 10/05/2016 9:55 am
