Fusion360 free only works with Cura???
david.b14
(@david-b14)
I downloaded Fusion360, free version. I see an option to send to Cura. No option to export a STL file or use any other slicer.
Can someone else confirm?
Update: To export to STL, it is not on the file menu. You have to click on the object and export.
Respondido : 08/02/2017 1:57 am
douglas.z
(@douglas-z)
Re: Fusion360 free only works with Cura???
When you click "Make" and select the body part you want to make into an .stl, just uncheck the box that indicates you would be sending it to Cura then click OK. It will then prompt you where to save the .stl file instead.
If you want to send it directly to a slicer but use a slicer other than Cura select 'Other' (or custom) from the dropdown then navigate to the executable of the slicer you want it sent to. It will use, and remember, that choice.
Respondido : 08/02/2017 7:17 am
