Firmware Updater Error Code
angus.g
(@angus-g)
Hey Guys,
Just tried to install the new firmware via the Updater supplied with version 1.6.1, after the Hex file is selected the status window shows the following error "Spaces are not allowed in path !!!"
Tried a few things, nothing could fix the problem. Eventually installed the driver package 1.6.0 which reinstalled the firmware updater from that package and this worked fine.
Tried reinstalling from 1.6.1 and got the spaces error again.
Might be an issue with the one supplied with package 1.6.1??
Angus
Veröffentlicht : 04/11/2015 10:58 am
LadislavM
(@ladislavm)
Re: Firmware Updater Error Code
Hi Angus.
Do you have both files (updater and firmware) on the same drive? If not, try to place them on same drive and then update.
Veröffentlicht : 04/11/2015 2:25 pm
angus.g
(@angus-g)
It all works fine with the installer from 1.6.0, just when I try to do it with the installer from 1.6.1. Thought it might be something for you guys to look into, I got the latest firmware downloaded with the 1.6.0 version. Have tried reinstalling many times, result always the same, works with the 1.6.0 installer and the error occurs with the 1.6.1 installer.
Angus
Veröffentlicht : 06/11/2015 12:17 pm
sly
 sly
(@sly)
hi, i have a huge problem with the update in the firmware updater it tell " Spaces are not allowed in path !!! " i try to update the last version from the HEX files" 1_75mm-RAMBo13a-E3Dv6lite.hex" inside this one " prusa3d_fw_2_2_3.zip" and it always make the same error message,
what kind of issue did i have
Veröffentlicht : 02/03/2016 1:30 pm
sly
 sly
(@sly)
OKAY FIRMWARE UPDATER 1.6.1 IS NOT GOOD REALLY NOT !!!!!
IF you have same issue download old version 1.6.0 it's working fine like angus.g told before . thank you angus.g .
Veröffentlicht : 02/03/2016 1:51 pm
justen.m
(@justen-m)
To solve this issue I dropped the .hex file right into the drive, in my case Local Disk (C:). I then got an access denied error which was solved by closing the updater then reopening it as an administrator by right clicking the icon and selecting "run as administrator".
Veröffentlicht : 23/03/2016 4:54 am
