Feature requests - where
The Plastic Shed
(@the-plastic-shed)
Whilst I can probably do this myself I really don't get that much time so where does one put feature requests such as ...
When needing to switch filament clearly an unload is needed, for this a preheat is needed, the current preheat heats both extruder and bed.
I think it would be much better if the preheat was built into the unload filament menu then only the extruder need be heated
Veröffentlicht : 20/01/2018 7:17 pm
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
Re: Feature requests - where
Check https://github.com/prusa3d/Prusa-Firmware there you can open an issue, Prusa team usually check these, just at this moment they are quiet busy with the MK3 firmware.
Veröffentlicht : 21/01/2018 11:02 am
The Plastic Shed
(@the-plastic-shed)
I've done so.
I also added a similar requirement for loading filament - including raising the Z access to the top or at least above 50%.
I don't know how this process works on a MK2 / 2S - since I have a MK3 - whilst I know there are workarounds they shouldn't be necessary when it is a simple process to eliminate additional steps for the end user.
Veröffentlicht : 21/01/2018 10:51 pm
