Convert to type K thermocouple
bob.s
(@bob-s)
Hope this is the right spot for this. It seemed closer to software than anything else...
I have bought the E3D Type K Thermocouple and the adapter board, but I can't find any explicit instructions on how to hook it up and adjust the RAMBo firmware to use the thermocouple instead of the thermistor.
Is there any info on this? A nice step-by-step would be nice. 😀
Thanks
Posted : 22/11/2016 3:50 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Convert to type K thermocouple
Bob
There is very little on this, other than what has already been written in these forums (a search should help). There is one change you will need to make in the firmware (the thermistor type setting in Configuration.prusa.h), then a compile and upload. There are a few places you can get a +5V/0V supply from the RAMBo, including on the P3 connector.
The existing firmware will allow up to 300 degrees with the thermistor.
Peter
Posted : 22/11/2016 3:55 pm
bob.s
(@bob-s)
Thanks Peter,
I think I have it mostly figured out. The two things I'm not sure about are 1) which pin to hook the analog input to, and 2) how to specify that in the firmware.
Any thoughts?
Bob
Posted : 22/11/2016 4:21 pm
PJR
 PJR
(@pjr)
Bob
Use the same pin as for the current thermistor.
Amend the line:
#define TEMP_SENSOR_0 5
to 20.
Peter
Posted : 22/11/2016 5:09 pm
ayourk
(@ayourk)
Also, I found this old thread on the subject.
Dimensions PNG
and an 8 inch (200mm) or greater caliper is recommended.
Posted : 23/11/2016 12:43 am
bob.s
(@bob-s)
Peter,
Further to the discussion of where to connect the thermocouple amp; due to the lack of any spare analog inputs on mini-RAMBo, it does need to use the same pin as the thermocouple (or another unused thermistor input).
However, I have also been advised that the 4k7 pull-up resistor must be removed. This seems like a pretty important issue to get the thermocouple working correctly.
I'm not too happy about this since it is a non-reversible modification, but I don't see an alternative.
Bob
Posted : 29/11/2016 1:01 am
PJR
 PJR
(@pjr)
Bob
// 147 is Pt100 with 4k7 pullup
I don't think it does ... It is already built into Marlin. Type 20 is without the pullup, 147 is with.
Peter
Posted : 29/11/2016 6:49 am
bob.s
(@bob-s)
Great news about the software selectable pull-up! I'll give it a try.
Bob
Posted : 29/11/2016 4:50 pm
PJR
 PJR
(@pjr)
Bob
Just checked and it appears to be present in the correct area of firmware:
#if (THERMISTORHEATER_0 == 147) || (THERMISTORHEATER_1 == 147) || (THERMISTORHEATER_2 == 147) || (THERMISTORBED == 147) // Pt100 with 4k7 pullup
const short temptable_147[][2] PROGMEM = {
// only few values are needed as the curve is very flat
PtLine(0,100,4700)
PtLine(50,100,4700)
PtLine(100,100,4700)
PtLine(150,100,4700)
PtLine(200,100,4700)
PtLine(250,100,4700)
PtLine(300,100,4700)
#endif
So it looks like it should work OK.
Peter
Posted : 29/11/2016 5:49 pm
bob.s
(@bob-s)
Peter,
Further research shows that the pull-up resistor on the thermistor analog pin is a physical one (not selectable in software).
This means that if the pull-up remains in place, there will be the 5v bias as well as the 0-5v signal from the AD595 on this pin. Will this work? I'm thinking not, but it's not my area.
I'm reluctant to remove the pull-up as it is SMD, tiny and hard to reach. It would surely be a non-reversible operation and looks like I could damage the board in the process.
Anybody with experience with this?
Bob
Posted : 01/12/2016 3:06 pm
PJR
 PJR
(@pjr)
Bob
In all honesty I don't know. I think you may want to contact E3D and ask them about interfacing to a RAMBo mini running Marlin. Or you could also contact Ultimachine.
Sorry, I can't assist further.
Peter
Posted : 01/12/2016 9:00 pm
bob.s
(@bob-s)
Thought I would post this here vs. starting a new thread. If that's a mistake please let me know...
I decided in the end to use a PT100 instead of the Type K Thermocouple.
I wired the output from the amplifier into the same pins where the thermistor was connected, and adjusted the firmware to
#define TEMP_SENSOR_0 147
based on this comment:
When I start up the printer, the LED display shows 300/0 for the hotend temperature. The bed is 24/0.
Obviously something is not right, but I don't know what. Any suggestions will be appreciated!
Posted : 17/12/2016 8:37 pm
