ColorPrint Webpage hanging
iain.s2
(@iain-s2)
I'm trying to add a colour change through the ColorPrint webpage. However, every time I load a .gcode file (produced by Prusa slic3r), the webpage hangs. I have tried using both Chrome and Edge with the same result.
Is anyone else experiencing this? If not, can anyone suggest a solution?
Thanks!
Opublikowany : 09/03/2018 9:34 pm
iain.s2
(@iain-s2)
Re: ColorPrint Webpage hanging
So...managed to answer my own question. There is a "ColorPrint" printer configuration within Slic3r. Not sure what the difference is, but it doesn't crash the website...
Opublikowany : 09/03/2018 10:53 pm
Hi Iain...
I had problems originally... i think I was being daft...
in this picture I have loaded a gcode file but not added any colourchange instances
in the picture below, I have added one colour change, by clicking the green + add colour change, box and adjusting the slider, there was an option to download the G code, but I didn't use it
in the picture below, I have added a second colourchange
and also down loaded the Gcode... now you can see the DONE!, Happy printing message... but on windows you might have missed the filename appear in the bottom of the screen... the gcode file was automatically downloaded back to the host directory where the original file came from...
there was no file name selection dialogue box, so it seemed as it nothing had happened...
hope this helps, Joan
Opublikowany : 09/03/2018 11:00 pm
