Color Print not working
sean.t
(@sean-t)
Color Print has only worked once for me. Have a Mk3.
I just did another print. I entered 3 changes. It got to the first change and I changed the filament.
It printed one layer then went through the change filament process again.
I unloaded and put the same colour filament in and, again, it printed one layer and asked me to change.
Any ideas?
Napsal : 19/01/2018 10:14 pm
Peter L
(@peter-l)
Re: Color Print not working
Are you sure this is a problem with Color Print and not the filament sensor? There have been a lot of problems reported with spurious filament reloads triggered by the optical sensor. Try disabling it and see if that helps.
Napsal : 19/01/2018 10:26 pm
sean.t
(@sean-t)
That seems to have fixed it.
I'm rarely going to be needing the filament sensor so that can stay off until needed.
Many thanks. 😛
Napsal : 19/01/2018 11:23 pm
